- Oct 13, 2014
- 10,302
Thanks for the useful info on the bearings, I'll know what to prepare for.
Yeah, what oil went into which cup was a bit murky at first, I think I have sussed out now. I do have a couple of the "grease" fittings but some research I did a while back, revealed they are for oil and a special pressure oiler is used to inject oil into them.
My noise issue is very intermittent, not even one out of ten starts and it goes away in less than a minute, a couple of times it happened when the machine was running for a while but again, it went away quickly. Sometimes, It can go for weeks or months without occurring. It sounds like it has something to do with the cone pulleys in the variable speed drive, maybe the belt slipping, but its baffling how it can be so sporadic. I don't use the power downed that often and keep it off when not in use so it's not related to that. My fear is I'll take the head apart and need the Mill to fix it, lol...
Another approach I am considering, is to "simply" replace the Variable-drive with a DC PWM motor and drive.
