Dan,
The 6" MK2 uses 2L belts. The 6" MK1 (612, 618, 101.07301 and 101.21400) use 3L belts. The 10" and 12" use 4L belts, except that the late 12" cabinet models also use two Multiple-Belt A-series belts.
The 618 and 101.21400 have a drill template that shows exactly where the M6-20B Countershaft Bracket mounting holes should be drilled relative to the rear left leg mounting bolt hole. I've never seen one showing the L9-20A Countershaft Bracket that at least according to all 101.07301 parts lists shipped with that model. There are at least two versions of what are supposed to be an Owners Manuals for the 101.07301floating around the Internet that have pages added for lubrication, bed leveling, gear clearance and bracket mounting. All four pages were probably actually produced for the 101.21400. The gear clearance and bed leveling ones are applicable as the beds and gears are the same and it doesn't matter that the leveling one uses a drawing of the later machine. The lubrication one is mostly applicable although it shows the later countershaft assembly. The bracket installation one probably isn't actually applicable as there are considerable differences between the two brackets and I have no way of knowing whether the nominal design running location of the countershaft spindle and the motor armature was the same for both models. Unfortunately, I haven't been able to determine the belt numbers for the 101.07301 but given the differences between the two brackets and where the hanger sits, I can't see how the mounting holes could possibly be in the same location.
