- Jan 22, 2022
- 144
VFD sounds like what I need then. Any recommendations for a brand or model? My motor is 5hp.There are 2 types of phase converters, Rotary and Static. You are referring to a static, which gives you half the power of the rated label.
A rotary can power multiple machines, a static cannot.
A vfd also powers one machine only. The VFD gives you full power, and allows you to control the speed of the motor, not a big deal on your machine. I believe the Colchester has the Reeves drive that the Clausing has.. I could be wrong, but it makes your speed variable throughout.
The rotary can be loud, or a good one can be quiet. The VFD is fully electronic, the static phase converter is mostly capacitors.
Just to sum this up… VFD is cheaper and you get full power?? It won’t damage my motor at all?
I wouldn’t mind looking into a VFD for my Clausing 8520. Changing speeds sucks on that machine.
