- Jan 20, 2015
- 361
Make sure you have a good belt on the oil pump. Its a crappy round belt that falls apart way to easy. I replaced it with an appropriate sized notched v belt with good results. I will have to look at the size. Its under the headstock on the side at ground level. The bearings are special spring loaded jobbies, not sure if they are available any more. I use TPU to print way wipers. They are very nice lathes to operate. One of the better lathes to thread on as well.
