- Jun 12, 2014
- 5,128
The mounting instructions are generic. The location of the limit switch depends on the axis and the machine. On the X axis it is typically mounted to the saddle as shown in the directions. Almost all drives are NOT machine specific and almost always requires fabricating brackets, standoffs, etc. to make them work. One of the biggest mistakes I see people do with DRO and drive limit switch installs is to try to use the stock brackets and kludge something together. Most of the time you need to mock up everything, make sure you have the appropriate clearances and then mount everything.
The wire at the bottom of the switch can be held in place with cable restraints to prevent it from interfering with other machine components. I would have no issues with using the saddle threaded holes or tapping new ones being very careful to not thread into something other than the saddle. In this case use the current holes in the saddle make a bracket and countersink the heads, then mount the switch to the bracket.
Quality of components is proportional to the price for the most part, but there are enough of these installed that I would be confident that although the switch my not look high end, that it will work. If I had a limitation as to the switch size or I wanted higher quality there are plunger type limit switches that could be used. I have installed these on custom axis drives that I have made.
