- Oct 13, 2014
- 9,232
Or you can do what I did and simply cut the pesky joist out!You can always position it between ceiling joists and if a finished ceiling frame out a hole for the motor.
Never Say Never!
Never Say Never!
Buy once cry once..... The the satisfaction of a low price will be forgotten long before the bitterness of poor quality....I decided that I wasn't going to be happy with a machine that was made in China so I cancelled the Grizzly and ordered a PM-833TV.
I'm exited yet I'm not really happy about needing to spend $5K to get what I wanted.
The 940 I have has the induction harden ways, for a hobby machine I am not certain the lack of that isn't huge as we are not running these for production, just do not drop anything of consequence on them and it will likely provide good service as long as you'll use it.That's my hope.
I'm still baffled that the old Buffalo Power BP1236 made in Taiwan lathe that my grandpa bought in the late 80's has hardened ways yet I can't find any made in Taiwan milling machines under $8K that have them. I don't recall that lathe being a particularly "high-end" model but I haven't been able to find much information on it since I got it from his estate a few years ago either.
At issue is the Work envelope, to get a knee mill with 22" of table clearance you will easily spend 3 times as much as the 940 cost.Yeah I saw that but man that machine is huge. I kind of figured at that point I might as well just get a knee mill.
I'll make some table covers to at least protect the table and be careful about dropping anything on the ways as I definitely want it to last a long time.
If I ever planned on converting it to CNC I probably would have gone with the 940 just for the hardened ways and table.
Aren't you 6' 6" it's dinky in comparison.Yeah I saw that but man that machine is huge.
I have a quote on a 10-54 knee mill for $12k. Like the 940 the spindle speed is 5,000 rpm. The problem is trying to contain the chips and oil/coolant that's going to fly 12 feet in all directions at that speed. Way easier to build an enclosure around a 940 (or 833) vs a knee mill. So I'm mulling over getting a 940. Also got it in my head to convert to zero backlash double nut ball screws, that's going to be less expensive with a 940. Servos will cost less than a knee. The 940 has been converted to CNC by others numerous times already.At issue is the Work envelope, to get a knee mill with 22" of table clearance you will easily spend 3 times as much as the 940 cost.
