How can I use a tool probe on the PM-728? I mean if I put it into an R-8 collet, then swap it out for the mill, the x-y and height info are lost. Is it possible to adapt one holder per tool using BT40 or similar?
Koenbro,
Take a look at the Tormach Tooling System (TTS). It uses a 3/4" master collet and exchangeable tool holders for repeatable Z height and quick clamping.
tormach.com
I have had good success with them. The system is appropriate for spindles up to 10k rpm and not more than 3HP.
For tool holders, there are a wide variety of styles available but you will mostly use set screw holders for weldon shank endmills and ER collet chucks for drills and carbide endmills without weldon shanks.
I have a mix of Tormach genuine and import chucks. They run about $17 per genuine Tormach set screw holder or import collet chuck and $35 for a genuine Tormach collet chuck.
They do add cost to your tooling but are really the best for CNC. Pair it with a pneumatic drawbar and you can change tools in about 1 second with height repeatability to a tenth or so.
I started with 5 ER20 collect chucks (good up to 1/2" tools) maybe 6 years ago and now have almost 30 different holders, drill chuck, boring heads, slitting saws, and electronic edge finders.
Tormach sells a small granite surface plate (6x9") with a hole in the corner to preset your tools off the machine using a height gage. I have this as well and find it to be an excellent method.
I do not own a probe, but I have a 3D edge finder (one of the electronic ones with a ball tip) and use that as my master. Once a part is zeroed with that, all my tool lengths will be spot on.
The import chucks are good quality (once you reject any obviously bad ones) but I strongly suggest paying the extra bit for Teknics ER collets. Import collets are just no good for runout.
I show these a few times in the build log for my mill. Here is one post regarding them and the pneumatic drawbar.
The machine is now as good or even better then when I started this upgrade. I am going to hold off on actual machining for a little bit, but if I need to use it, it is ready to go!
www.hobby-machinist.com
-Mike
