- Sep 22, 2019
- 1,098
If you can get a 1" x 2" long annular cutter, you can core the hole form both sides, saves a lot of time. When I make lathe spiders, I use the annular cutters for solid round stock, takes 1-2 minutes from each end (usually on the lathe), then I follow with a boring bar. You could also do it on the mill if you have a jig/stop system to keep the alignment.Three passes the last with a 1" bit in the Mill.
Thanks for the review, please keep 'em coming as you test all the functions!The Kickstarter project by YesWelder came in a few days back. It does MIG, Flux-Core Wire welding, Stick, TIG and Plasma Cutting. We set up the plasma cutter to slice a 4 by 8 sheet of 12 gauge steel to a more manageable pair of 4 by 4 sheets.
Current was 22 amps, 35 PSI (0.24 MPa). It cut the steel like butter.
Hadn't heard of that one. Yeah, plasma is really really nice for some things. It's second only to sending CAD files out and having parts laser cut for you!Something simple. The Kickstarter project by YesWelder came in a few days back. It does MIG, Flux-Core Wire welding, Stick, TIG and Plasma Cutting. We set up the plasma cutter to slice a 4 by 8 sheet of 12 gauge steel to a more manageable pair of 4 by 4 sheets.
Current was 22 amps, 35 PSI (0.24 MPa). It cut the steel like butter. The angle iron was a fence, to ensure a straight cut.
The step son was testing out his Christmas Gift. He is attending welding school.
