- Nov 25, 2015
- 10,164
what do you mean someone came over and just destroyed the cowling? Did you beat the crap out of them?
Is said A hole still breathing? Need to borrow my backhoe?Sat the tractor out back yesterday only to have some high A hole completely tear the cowling up . So now it's back in the garage .
I was watching this guy from the garage . He walked around it numerous times and made a few phone calls while doing it . He then just yanked the hood up which you CAN'T DO on these old JD mowers . The front ends of each side need to be pulled out to clears the locks to release . I took the Kubota out , looked at the tractor and let him know he just destroyed the hood and should've called me before he touched it . " Uh Oh , I just wanted to know what motor was in it " was his response . Dumb ass could have asked me . New hood on the way for $200 . The $$$ doesn't **** me off , but the fact that the tractor is now back in the garage does . For the first time in years I had some space to work in there , but hey , I guess the tractor is in to work on it .Maybe there’s a reason Dave mentioned the chainsaw?
If it is not to bad then you could try lapping it with an existing MT2 shank, preferably a non-hardened one.so I spent half the day searching for a tool I made a year ago. I needed it to fix another tool today.
https://www.hobby-machinist.com/thr...ou-make-in-your-shop-today.67833/post-1055846 wish I could find it. I have a bunch of rounded turning tools, but the material was difficult so I wanted the tool. Looked everywhere but where it was, or maybe I just didn't see it. .
I was making the changes that @tonyfoale made to his HF vibrator.. I used too thick a piece and now need to remove a lot of material. I may need to make some new spacers and get some 4mm 30-35mm long screws, as even after I relieve the boss on the plastic platten, and shorten the shaft, there is no room ... I wonder if they changed the plastic mold or changed who built the vibrator .
edit: Also spun a MT2 taper drill bit in the lathe center today. , not once but 2 or 3 times. When I went to pop it out, it was not coming out smoothly. Well, it galled, Now I have to buy an MT2 taper reamer to clean it up.
do not use 12L14.. You don't want a pen with lead . if your put it in your mouth, or just from sweating in your hand, would not be a good thing.
@SouthernChap 316 and a 7x?? Never had a problem with a decent finish even though that stuff is real honery to machine!
Did you take off a quarter of an inch off in one pass?nobody's going get a good surface finish trying to take 0.250" off 1" 316 stainless in one pass
It may take time, but you will learn feeds/speeds/Depth of cut et-al for each material. A lot of it is down to experience, so you will find, with time, that develop a "feel" for each material.
