what kind of fish is that?
It looks similar to the jade perch in my aquaponics system except for the large mouth.
Largemouth Bass.
Well, the hardware for the vise is all too big to go into the slots of the table. The vice came with a swivel base that I didn’t want to mount & keep on the table. I’m sure the hardware would work fine if I mount up that swivel base then mount the vise to that. I bought a clamping kit with the 727 & what I have mounting the vise is the shortest studs in the kit.@RandallsRaceShop
I think the knurl headed brass screws look fine.
I am curious about the spacers though. It looks like a stud to may be above the bed of the vise (no good). Why didn't you simply buy shorter studs (or use long set screws) rather than make spacers? What am I missing here?
I told YOU I was making progress Jeff ! Just don't look at the back wall .I see some floor there. What happened?
Very risky to have fully threaded T-slot nuts! One wrong use and your mill table casting can be broken!T-slot nuts are available fully threaded through as well as partially threaded (so a bolt/stud will not extend through the bottom). Whatever fastener combination you end up with, if your T-slot nuts are fully threaded through, be careful that your studs/screws are not bearing on the bottom of the
T-slot.
My solution (3" vise, swivel base removed, on a Mini-Mill):Well, the hardware for the vise is all too big to go into the slots of the table. The vice came with a swivel base that I didn’t want to mount & keep on the table. I’m sure the hardware would work fine if I mount up that swivel base then mount the vise to that. I bought a clamping kit with the 727 & what I have mounting the vise is the shortest studs in the kit.
Sounds like what I have done is wrong. I’ll chalk that up to my inexperience & also point a little bit to the guy that sold me a used PM25MV had his vise mounted to the table the exact same way.
The vise isn’t on the table right now (had to tram the head), so I’ll take a look at what length studs I need & go get something of the correct length.
Long story short, I walked out to the shop a little while ago & wanted to make the mounting situation better (no spacers).Easy enough to fix. I like to have the vise hold downs as unobtrusive as possible so they seldom get in the way.
You could probably get socket head cap screws and thick/hardened washers, at your local hardware store, that will work nicely.
You could also get shorter threaded studs or socket set screws to use with the nuts from your clamping kit. McMaster sells studs 1.5" long (and longer).
T-slot.
my shop for sale, Livermore Falls, Mainemade a new Bull gear for my Standard Modern 13" 2000 series lathe using a modified off the shelf Boston gear YD72, now its smooth and quiet.
well quiet as you can get with a gearhead lathe.
old gear had a repaired tooth with a noticeable clicking sound while running.my shop is for sale, follow link
