Today the Jet VBS-900 bandsaw is operational. Mostly. Well, it cuts. Upgraded the motor from 1/3HP, which was way too small, to a 2HP new Baldor, very quiet and smooth. overhauled the air pump, with new bearings and a new shaft assembly, it also is smooth, but sounds a bit like those playing cards in the spokes, anybody remember that?
The blade guides were stuck, so removed and cleaned, pressed out and polished the guide pins so the adjustments work smoothly. Scotch Brited the two tables, came out very acceptably. A new blade mounted easily, and chips were made. Wow, so nice. This is going to up the scope of the projects I can take on.
The thing has a 4 speed transmission and a Reeves drive, so there’s an infinitely variable and wide range speed selection.
Now sadly the welder/grinder is still a wireball. What a great hobby, we’re never done.
Last picture is as it arrived. It looks about the same from the outside.
It needs a belt to run the air pump. I now have all the parts to do a solenoid valve for shop air, just flip a switch…hard to decide.
