Worked on the yard sprayer as we received all/most of the parts.
Rewired the unit as factory wiring was odd with an extra creator that stated not to use as it would blow the fuse.
Redid the water lines to get them out of the back cover and a fitting on the frame.
The wand is rated for 4000 PSI, so it works really well at 60.
The spray nozzles fit the fittings perfectly, but the spoiled with a long wand is after you release the trigger gravity still feeds material.
Real pain as some air gets in to pressurize it.
We found these little check valves on Amazon, perfect!
They require some effort to work, so the spring will easily close the valve, so no drips.
Replaced the battery and added a bit longer hose
Works were well now.
Next is making a micro-sprayer using the mister nozzles, but we need to add a filter for those.
Sent from my SM-G781V using Tapatalk
