I think the bluing isn't that good in the threads, maybe due to residual oil, but overall, have to say I like this. Next time, I'll probably boil the parts in TSP first. I didn't' want to do that with our kitchen pots. Have to find a cheap pot somewhere.
that's thinking outside the box. Very cool.. So the knurled piece is basically the taper of an er32 and presses up against the front of the collet?I made some ER32 collet blocks without the bulky nut to get in the way. They're also accurate on all sides within .0002".
I wish it was my idea but no. I was thinking it would be nice to make a block with the nut not being bigger than the block like most of them are. I saw a video on Stefan Gotteswinter's channel of a really nice collet block so I made a couple also.that's thinking outside the box. Very cool.. So the knurled piece is basically the taper of an er32 and presses up against the front of the collet?
pics of the construction or pieces?
I've had really good luck getting things clean with dish detergent in water in an ultrasonic cleaner. Like, get things to clean that stainless steel will rust type of clean. Even the low cost import ultrasonic cleaners are very good. $60 gets you a pretty nice machine...
Nifty trick, use a plastic bag to hold the part, water, and detergent. And fill your ultrasonic with water then add bag of parts to top it off. You waste less detergent for small parts, and save having to get soap out of the ultrasonic cleaner when done. I have a stack of polyethylene 'zip loc' bags, and run all sorts of solvents this way (acetone, paint thinner, alcohol, etc.)
Activated charcoal filter - takes out chlorine and other stuff out of water. Use it for filtering water for drinking. Distilled water would work fine too.
We have an EverPure H104 filter for kitchen cooking and drinking.
