- Jan 20, 2016
- 602
On mine, there is one side of the gib that has the snowflake scraping pattern in it. That is the side that faces outward toward the opposing dovetail. The little notch will fit in with one of the gib screws. If I remember correctly, the notch goes on the right side. If your table is the same as mine, it weighs 66.7 lbsThere is a slight notch in it. I'm assuming this notch goes to the right and down? Is that correct? I also had to re-position the little X axis indicator to remove the table. The table is heavy. It has to be at least 80 lbs I would guess. It weighs at least twice my entire Sherline mill weighed! Hand carried to basement.
I think the only thing that would get the grease off for me was acetone. Isopropyl alcohol and mineral spirits wouldn't touch it.I want to remove all the grease on the table first. Any ideas what to use?
It might be just the pictures and lighting, but wow the paint on your column and Z axis slide look really nice. Much better than mine looked! I love new machine days!
