I don't know what went pop but, I'd start by looking at all the connecting wires under the cap. It's possible the oil pump got tugged on during shipping because it was tacked with plywood to the shipping crate. Unplug the unit before checking the wires, of course...
It sounds like it's working if you've got oil leaking all over... That's what you can expect. The oil gets pumped into the table way areas and it drips down all over the place. It also gets slathered onto the leadscrews etc... Under normal circumstances you'll just wipe the excess off.
Mobile Vactra #2 way oil is the appropriate lubricant.
Ray
Thanks Ray,
so what is the appropriate process for lube? When do I turn on the pump and for how long? If done correctly will excess lube return to the tank? I assume it is as mine turned colors.
Thanks,
- - - Updated - - -
this may be stating what you already know but the one-shot lube system as implemented on the PM45-CNC is not designed to be turned on and left on. I turn mine on for 10 seconds before I use the mill each day that I use it. I am not sure if this is long enough, I plan to experiment with longer and longer times until I see excess oil.
Also a note of caution. Twice, I have realized that I forgot to run the lube until the Mill was running a program so I reached up and did my 10 second routine while it was running. When I turned the lube switch off, the spindle turn off also. Mostly likely some electrical noise or voltage drop that caused a relay to trip or fall out. Regardless, you have to hit the stop switch quick or bust something. The only way I could get the spindle going again was to turn the Mill OFF and back ON.
Good info here, thanks.
