Great news.
Now you have English and a working Spindle. Go make some chips and let us know how it goes.
Got an exciting update!
My buddy just came over and we were looking at it and I was explaining the problem to him. He said it sounds like a clutch problem. So he starts messing with the spindle and gear selector and said it was just out of gear. By turning the spindle it allowed the clutch to engage and when I hit the spindle power button it worked!
So it may be as simple as it not being fully in gear. Hope this helps someone.
- - - Updated - - -
This is what I was hoping for. I kind of felt like I was alone in this, glad to help and be helped. Thanks.
I will try changing this right now and report back. Hopefully Matt comes up with better instructions for future users.
- - - Updated - - -
Got English! Thanks for the fix.
AJG308,
I wish in your same exact boat. I remember loading the chinese version first and thinking oh this must be the wrong one and then installing the 1.58 driver. then once i went back the mto the chinese 1.56 driver in chinese my mill ran awesome. I will try changing my Mach3 from Chinese to English and post my results last night. i found a link to change that said go to view and click Load Screen...browse to the mach 3 folder and select 1024.set and this will bring it back to English. i have not tried it yet but i will tonight.
I agree this should have been a much easier setup from PM. I was frustrated because i am noobie with CNC and was looking for a simple mill to get me started. once we figure out all the issues this should go smoothly.
Ray you owe us a steak dinner for figuring out all these spindle problems.....lolol. This will make the problem solving section of that work instruction a little easier.
Today I ran the PM45-CNC in all the gears as described on the website. I thought I should turn on the lube pump and when I did, bang! A loud pop and from the pump and a tripped circuit breaker in the breaker box. I tripped it back, and everything seemed ok. When I had the balls again I hit the pump again, but nothing happened, I was not sure if it was even working. I determined it was working because the oil went from new and semi clear to dark brown and then black. I also have quite a leak coming from somewhere in the table.
My questions.
What freaking happened? Is the pump ok? Can I test it besides Ray's method? How do I find the leak? What is the best oil to replace it?
Thanks, everyone.
My questions.
Thanks, everyone.
Anyone know what the rpms limit is for the two different gear selections?
