Thanks for the glowing remarks - much appreciated. This was definitely a labor of love. This machine was under glass cabinet on tour for a solid three months with Taylor Swift as the warm-up act prior to local unveiling and touchy-feely encounters. Just kidding. But I'm close to pulling the trigger on my next customization project involving a PM935 mill. Hold your breath, this is going to be a Mardis Gras experiment in celebratory style. LOL
I'm certainly no expert on stands and lathe mounting arrangements, but I understand your question. Yes, you might well be guilty of overthinking this a bit, just like me. Two things were paramount in the lathe stand for my PM1340GT: 1 - it had to have all drawer storage below (no deep cabinets with hinged doors or shelves), and 2 - a removable chip pan. Bss1 and I were actually working on parallel paths at about the same time. Obviously, we took different directions in some regards, and my guess is that we're equally happy with our decisions (not speaking for Bss1, but how could you NOT love what he came up with?).
One of the design differences between our two stand builds is that Bss1 took a more traditional 4-pillar approach to the section under the headstock. The commercially available stands are out of the same school of thought, and I'm in no position to question or criticize that approach. It's probably the more conservative route, but those who know me at all would quickly remark about my rebel nature. The design philosophy with this approach is to support the headstock platform by mirroring the headstock base bolting arrangement. I thought a lot about this when I did my design, but all the concepts I came up with that mirrored the headstock base attachments were in conflict with the two objectives mentioned above. There is NO drawer cabinet that I could find that was narrow enough to fit under the headstock platform, and deep enough to make use of the space. I even explored a $4,500 solution from Lista and even that was unsatisfactory to me.
So as you can see, I elected to take a different approach entirely, supporting the entire lathe on a robust C-channel steel beam at both ends. That gave me lots of freedom to include a removable chip pan, and to have tons of flexibility below the main beam to use drawer cabinets for storage. I'm guilty of lathe leveling paranoia in a couple of areas (which I think is also your paranoia if I read your original post correctly) in that I elected to use fine thread leg levelers (coarse would have been fine) and I duplicated the lathe bed leveling arrangement by having one set of levelers at the floor interface level, and a second set of levelers at the support beam level.
Based on my experience with this lathe and the custom stand over the past year, I can offer the following observations:
- I'm glad I stuck to my goal of having all drawer storage below.
- I'm also glad I used drawer storage units that were full depth, and did not employ the flip-up-top variety found everywhere. I've been a sailboat owner most of my life and really value every inch of available storage space. Making my own cabinets below was worth the effort, but not something I'd advise for those devoid of OCD.
- After every job I do, I pull out the chip pan and rinse it down over a garbage pail, so that was a good decision too.
- As for leveling, I first made sure that the four corners of the stand were on solid concrete footing. This required drilling out my plywood subfloor and putting in 3" diameter aluminum supports sized to the difference between the concrete floor and the plywood subfloor above it. That gave the required "footing" for the lathe stand. Thus far, I have only used the floor leveling feet to adjust the alignment of the lathe bedways. The duplicate set of adjustments at each end of the C-channel were frills. As I move into my 70's they may come to serve their intended purpose, eliminating the need to get down at floor level to dial in the bedways.
- I bought and used an MT5 precision ground alignment shaft to dial in the headstock. This is a wise investment IMO no matter your lathe stand configuration. Saves a lot of time and makes it super easy to verify the headstock is precisely aligned to the ways. I found the one I bought on eBay. Here's an example: https://www.ebay.com/itm/5MT-LATHE-...697186?hash=item3d36298aa2:g:yFsAAOSwCGVX2Zw6
- Were I to do this over again, I would make a few changes. The leveling feet I used were fine thread 1/2-20 when coarse 1/2-13 would have been fine. The removable chip pan could use an additional 1/2" clearance under the C-channel - when it's full of chips, it's difficult to remove without the chips being displaced onto the top of the storage cabinets below. I think next time I'd use a conventional Alkyd enamel paint on the stand instead of the 2-part (expensive) epoxy paint that is very difficult to apply and clean up.
But from a leveling and alignment perspective, based on my experience with this setup, a six-pillar stand is not necessary to provide the required rigidity, or to dial in alignment so long as you anchor the four corners to a very solid footprint, and the stand itself is rigid enough to not go into helicopter gyrations on it's own when the lathe is under stress. The lathe bed of the PM1340GT responds just fine with four leveling points provided you also dial in the headstock after the ways are level.
I know several people with this lathe that have had issues with vibration from various sources impacting surface finish. Some of those problems have been the stand employed (which became the motivation for Matt to pursue a cast iron stand alternative), some have been badly balanced drive pulleys or crappy V-belts, and some have been harmonics from the motor with plenty of evidence that single-phase motors are worse in this regard. Although my stand design is probably a poster child for setting up tons of harmonic vibrations, I have experienced ZERO problems in this regard. I attribute my success in this pursuit to the fact that I swapped out the OEM motor for a Baldor 3-phase vector-rated motor, replaced the pulleys/sheves with new balanced cast iron versions, and also replaced the v-belt with Gates BX27 Tri-Power belt. See details here:
If the machine is well balanced in it's drive system, I'm not convinced that a cast iron stand is required, but it certainly removes a lot of fear, uncertainty and doubt.
After all that, I will add this final comment: I got lucky as well.
As for the control system, Mark Jacobs is an absolute gem - a delightful person, sharp as a tack, with a knowledge of the control system subculture beyond imagination. I am forever thankful to him for his assistance in my education and his contribution to this project. Mark is present on this forum under the user name mksj - you can message him directly on this forum.
Hope this was useful - it was fun to pen.
