You might enjoy this link. LOLYou guys seriously need to stop posting about your upgrades. Just when I thought I was happy to have my 1340GT I see yours and feel like I have a toy again!! Nice machine!!
Hello David,You might enjoy this link. LOL
One thing additional that might help. See the attached. This is what inspired me to do the single-shot oiler.Hello David,
I have a question regarding the oil drain plug for the head on the PM1340. What type of thread is it? Did you have to drill and re-tap for a standard fitting when you made your oil drain system? I think this modification is very useful and I am about to do it on mine. I am also installing a one-shot oiler for the QC gearbox. I was also thinking of running an oil line to the 40T gear right at the input of the QC gearbox. This is the one that makes a "clanky" sound as it turns. I noticed a bit of oil makes it really quiet.
Also, my QC gearbox vibrates a bit at low gear ratios. Seems to go into a low frequency oscillation at it turns but only at low gear ratio. I am not sure if this is just a break-in issue or a bigger problem. I will take a look tomorrow, but was wondering if you have ever experienced anything like that on yours.
Thanks,
Salah Zenieh
Thank you- helps a lot. I will take a note of your second message also as I look into the vibration problem.Salah,
I have not had problems with vibration. I attribute this to the design of the stand I developed, and the fact that I replaced the factory motor with a Baldor 3-phase vector-rated alternative driven by a VFD.
The oil drain plug on the 1340 is 1/4" NPT. Here are some photos of the quick-change plumbing I came up with to make it easy to change oil regularly.
Hope this helps.
