So you are running a larger buffer and that solved it. Good to know....
Mine was automagically set, probably the default. I'm using a computer running widows XP, btw , which may have less overhead / more efficient. And coupled with a possibly faster computer I can get away with the default settings.
Yeah, I tried it with the same buffer that you have and it still had the same problem. I wonder if this has more to do with the speed of my computer. The computer I have on the mill right now is pretty weak, even as far as XP machines go. I have another one that I can get setup to run XP, I'll probably start that process over the weekend, along with transferring all of the settings.
PZ
