I'm placing my order the the PM-940 cnc tomorrow. My original plan was to place it up against a wall. Then I realized that the service electronic cabinet is in the back. I contacted Matt to ask if it's possible to relocate the cabinet to the right side of the mill like the Tormach 1100, also for the back wall clearance if I didn't relocate.
Matts reply was:
As far as the back cabinet, I have had people take it off and put it in a different location, but that takes quite a bit of work. Not impossible, really its just extending the wires for the axis motors and a few others for various controls.
The cabinet doors are about 13” Wide, so you’d want about that much room in the back to be able to open them up all the way.
I then asked Matt for any tips or hints to make it easier.
The only tip I can really say is do one wire at a time, then it should be no problem.
Finally, I asked Matt if doing so would void the warranty.
no it doesn’t void the warranty, unless it’s a part directly affected by that, like if you cross wires and something burns up, then yes it would affect that, but in general, no, just moving the cabinet like that doesn’t void the whole warranty at all.
So far the pre-sale experience with Precision Matthews as been great. I'm hoping for the same experience after the sale.
Anyway, has anybody relocated their electronics cabinet? Did you run into any issues?
Finally, since my mill won't arrive for 4 or 6 weeks, I would appreciate it if a member would take some detailed pictures of electronics cabinets and if possible the wiring. Different angles would be great. I would like to finalize the mill position in advance of delivery and if I will relocate the cabinet or not.
Thanks in advance for your help.
Rod in San Francisco
Looks pretty good.
What did you end up doing to get the spindle running with the nMotion?
(Edit) It sounds like the orange wire is the culprit. You could verify this by opening the box that houses the E-stop button itself to see if that orange wire is connected to the E -stop. If all else fails try wiring the E stop directly to the Jamen controller card, to test it.
Hey PhazerTwo,
These are the settings I am using so far. ( see pictures )
1) Motor Output 2) Pulley setup, and finally 3) M-Codes to get it to spin. ( I have not run any G-Code yet, hopefully tomorrow after I finish tramming.
The M-Code I used is M4 S400 , Then M5 to stop it. S400 is telling it to spin at 400 rpm. You must indicate the speed or it will not execute the M4 command. While it is spinning, you can change the speed with a simple S(rpm) command. M5 is used to stop it. I believe M3 is for clockwise rotation. Don't forget to choose the appropriate pulley for the rpm range you want. Let me know if it isn't working after using these settings and I'll see if I missed anything.
edit : And if the spindle is spinning in the wrong direction its very possible you need to change your motor wiring.
btw, I finally checked my backlash properly and found I have .001 in the X, and .002 in the Y and .001 in the Z. I'm not terribly happy about the Y, maybe someday I'll get oversized balls for the Y ball nut and repack it. When you get yours checked hopefully you can post your backlash results ?
Cheers,
Jake
Have you been running with your X, Y, and Z on those settings? That's not what I have...
Our spindle settings actually do match. I thought you could just clikc the "Spindle CW" button to fire up the spindle... I will give the G-code a shot and see if that fires it up.
PZ
