- Apr 22, 2018
- 12
Is this strut used for lifting car rear doors? I went on amazon and looked at lifting struts.
By using this strut did it make lowering quill harder?So this was a super helpful thread as I considered a new mill. I ended up with the PM 932 as well and am quite happy so far. No major grit in mine, just a light wash with kerosene and complete re-lube and I was good to go.
As I started to use it I struggled with the quill backlash as well so stole the OP's great spring idea but modified it slightly. I got a puller gas strut from Amazon and replaced the silly drill press depth gauge with the strut. I spec'd 40lb pull but probably would pick 30 if ordering again.
I had to drill out the hole in the bottom of the gearbox to allow the body to partially pass through. That is also the support, there was no need to make an upper attachment, I just used a die grinder to make a ledge for the body of the strut to sit on. Out of gas on the tig today so used the mig glue gun to ugly effect on the adapter.
Works great, no more sudden 0.050" drops and jumps.
Alex
Not necessarily. Depends on the distributor's specs and where the machines are sourced from. Taiwan is certainly better than China. I think you may have meant Pacific rim, which would also include Japan.LOL welcome the biggist problem with the Asian rim machinery. The quality sucks.
