- Aug 22, 2012
- 4,271
In my never ceasing search for more rigidity in my lathe I decided to make a plinth for the qctp.
In its normal configuration I can often see the complete top slide assembly flex slightly. (I think I punish my lathe a bit)
After seeing Bill G's plinth I felt it was time to go.
I forgot to take pics as I started but the base was a chunk of mild steel hot rolled plate 19 mm thick.
I faced all sides in the 4 jaw and I must say that facing the sides jutting that far out of the 4 jaw was a bit wild.
The centre hole was drilled and tapped for 14 x 1.25 mm.
The hole in the qctp is 14.7 mm dia so I turned the centre post down to 14.68 mm, it slides on firmly but smoothly.
I needed more height so the central boss is 19mm x 57mm dia. Its bored to 14.68 so the post is pulled down into the hole for a very very tight fit. Then I welded the boss to the base plate.
I made it round so the tool post holders can sit down lower, this allows 1/2" tool bits a bit more height adjustment.
I took a skim from the middle of the base plate to ensure it sat dead flat on the cross slide.
I also took a light skim from the top of the plate to remove all the weld spatter.
Now I needed a lump of 50mm dia bar and there was none available so I turned a taper into 2 chunks of 19mm plate
and welded them together
and then turned and tapped for the 14mm post with a 10x1mm hole for the handle.
All in place but waiting for balls for the handles.
I hope to try it out tomorow.
The handle isnt horizontal as it looks in the photo but tilted upwards the same angle as the taper on the top nut.
