Pinging jumps4
Hi paul
i finished the drawings converted them to cam and started machining the brass today
i still have some grooves and pockets to do manual tomorrow then these are done on my end. i decided to let you use transfer screws to locate the holes for the screws. my counterbore probably wont match yours.
i have to find some brass or copper to make the wipers from, i have the felt to crimp in the brass and the lower brass piece
steve
DSCF0723.JPG DSCF0724.JPG DSCF0726.JPG DSCF0727.JPG DSCF0729.JPG DSCF0730.JPG DSCF0731.JPG
Those really look good Steve. thanks for taking the time to do it. I checked my transfer screws and I do have some 10/32 I was surprised.
Paul
I got my parts from Steve and I have made a little progress on them. First I had to get the wholes laid out and drilled. Then I had to make a counter sink out of a 1/4 drill bit and that worked out ok.
Next I had to mill down some brass for the bottom, The only thing it does is keep the oil from running down the front. I've got all the stuff soldered in but I need to do some more clean up before I put the felt in.
Steve did a really great job on these. Couple of pictures.
Paul
Wow, great stuff here. I appreciate your generosity and communications. I needed a bit of good people in this world today. Thank you for the smile.
All the best,
Dale
Cleveland OH
