Pass Around 2022
Status
Not open for further replies.
When I had the box I could not find any of my 6 benches (let alone clear a spot on one), I had to do a new one just for the PA box.
The box is on the way to @finsruskw.
I think I've solved why there have been so many problems with the Rivnuts (and similar). When I removed the cover screws, one of them required enough torque that I was concerned the nut might fail. The nut survived, however I noticed that the threads were damaged near the end of the screw . . . . Eureka. The screws I removed were mixed lengths, some 1/2", some 5/8". Both screw lengths, when the cover is installed, extended well beyond the end of the nuts (various types now). That projection, beyond the nut, makes them vulnerable to damage from the contents of the box, as well as potentially doing damage to contents. I bought 3/8" long screws, put some in the "spares" package and installed the cover with same. I think the 3/8" long screws have adequate engagement for this application and they should be exempt from being damaged by the contents of the box. Slightly less than what I call snug is plenty tight enough for the cover screws.
Below is what I took out.
Left to right, top to bottom:
Pinion shaft, 24 T, 24 DP, 14° PA, 3ea SPG 634, Gr. K42 Inserts, 1ea SPG 633, Gr. T5 (Cobalt HSS) Insert
5ea TPEE 731, Gr VC8 Inserts
ER20 1/8" collet and ER20 Nut, 4ea 1/16" hex keys, 3/4" sq. HSS tool bit, 1/2" x 2" annular cutter, 2ea 1/4" brass laps, 2ea 5/16" brass laps, 7/16" x 3/16" power bit, 7/16" x 1/2" power bit, 1/4" x 5/8" LOC x 3/8" shank 3 flute roughing end mill, 5ea assorted Letter drills, 1/2" stub drill
6" Bastard half round file
8" double ended tri-square file
6" double ended tri-square file
The box is in my possession as of Tuesday evening, 6/21, was on my doorstep when we got home, right on schedule according to USPS!!
However it will be Friday evening before Les gets back from this weeks run to MT and I am waiting til he gets home to open it. It arrived in fine shape w/no visible issues.
Should have it back in the mail on Monday then so will the next fellow on the list please contact me w/your shipping info?
@finsruskw
Thanks for the update.
Please send a "Conversation" (commonly called a PM for Private Message) to the next fellow on the list to request his mailing address. Each participant should be "Watching" this thread, but you can't be certain of that. If you send a PM, you have done your part to promote the flow.
TIA
@finsruskw
TIA
For everyone else, list of participants is here:
Coincidentially, _I_ am next on the list. I'll send @finsruskw my address in PM anyway.
Box will be back on the road around noon today!
Here we are going through it and what I removed.
Son Les and my Great Grandson on the left.
Great fun!, $16.10 worth even if you don't remove anything!!
Hey Buddy , I like your style ! :encourage:
I just got the box in yesterday evening, but didn't get a chance to look at it, I hope to do so today! @Brento is next in line, so I've PM'ed him for his address!
Status
