- Nov 16, 2012
- 5,596
I hear what you're saying. For your setup it doesn't work. I leave my compound at 30 degrees but when I use the parting tool for a quick shoulder groove, I just loosen the QCTP and rotate it to be perpendicular. Quick & dirty. All the threads I do are typically just an inch long but they're oddball because it's usually 18 TPI with a shaft diameter anywhere from 0.75" to 1.25"... Sometimes it's metric though and usually 1.25 mm/Thread.
And yes man, I get my share of thread repairs on those shafts. They come in banged-up and I need to line-up threading tool carefully as there are no dies that I know of (or can afford) with those oddball sizes..
Ray; One of the main things we do is threading, so much we had to work all day Sat & Sun. for Monday. And I hate production work or my back hates it.
The job is 5/8 bronze with double end 11tpi. in range of 12" to 28" long. My first thoughts are; 4jaw chuck is out, 3 jaw is junk, has to be done on
centers. So the GK 1918 will center drill one end & campher, flip it do the same thing, thats all that lathe will do. Now it goes to my Model A I love it.
to thread between centers. Back to the post. correct or not I dont care, as my compound is set to 29.5 I stick the parting
tool in it, and do a releif cut for the depth I have to go or close, it doesnt care! Im thinking if this is to be steady work, I think I'll have to break down,
for a quick change for the GK thats big bucks then my son can do the centers champhers and releif cuts. one less thing I have to do.
I hate to be long winded or whine, kick in the buck, Sat. after 75% done customer comes in and now wants one side threaded to 3 Inches. If anyone
knows whats involved with adding on to a perfect thread with a releif cut?? just ask my back; there went Sundays lawn mowing. And then I had a
brain fart! Have a new one of those saw blade craftsman clocks Chrismas present, new, stuck it behind lathe. zero it, and I got it down to nine
min. dead start to finish (for one side) cheap time clock. hey good idea a real time clock conclusion; for this, no need to be perpendicular parting
a releif cut for threading.
