For goodness sake.
Take the time to learn and do it properly or line up a good eye doctor.
Theres a good reason you haven't seen it elsewhere. Its just plain dangerous and an accident just waiting to happen.
I am saying whats on my mind rather than remain silent and hear of someone getting hurt.
Guys,as they say it ain't rocket science. I regularly part off with HSS through stainless 303 and on occasion 316.
Ok these comments do apply to non production amatuers . I am not a jobber, so time is not a factor for me.
Observe the basics.
* Part off at center height
* Part off square to the axis of the work -check set up AND that compound setting is on zero.
* Set up for the minimum of PO tool overhang - half diameter of work + a smidgin
* Ensure the rigidity of your tool holder and tool post
* Use a constant (cross) feed
* Where necessary use a lube - on stainless mine is a sulphur base lube
* Sharpen the HSS tool as per info available -its there on the net
* Watch for the curl shape of the swarf that comes off the steel - the shape, size and texture tell you so much .Most times with a lot of steels comes off like a cursive writing "C" and usually is very shiny at the cut face.
I am certainly no machinist, merely an amatuer of some 8 or nine years experience but decided very early in my machining hobby to learn about using HSS. It has paid off in terms of economy versatility and not needing a wide selection of carbide cutters and tool holders.
It took a bit of time , effort and study plus chatting to an old timer and I was parting off trouble free with HSS within 6 months.
I hope this can help someone. Experienced machinists feel free to jump in and add something I may have missed.
Regards
Ozwelder
