- Oct 31, 2016
- 130
...looks like this op/set up is catching on!...I wonder if the original got a patent? (We better lawyer up!)...smiley face here
If you can release a threaded spindle with a hacksaw blade you are a better man then I am. I once owned a threaded spindle machine and unscrewing the chuck took considerable effort if it had been in use for several months or years.If your spindle has the chuck screwed on I would suggest you do NOT try this. The original has the spindle running in reverse. The teeth on the blade set to cut that way. One snag of the blade and you wear the chuck.
"Billy G"
I have actually spun a 20" 4 jaw chuck off of a threaded spindle, I fully understand the outcome of such a thing happening.With all due respect Wreck, read on please.If that blade jams or bends the teeth will jam or bind. If they jam the spindle could come loose.
FWIW, I have a spacer washer on my spindle between it and the chuck. This makes for easy removal of the chuck after long periods of use. A set up like the first one with the spindle running in reverse will have the chuck loosen and come off if that blade jams.
I leave you with this phrase, "Just because you haven't seen something happen, does not mean it can't happen.
"Billy G"
