Parting Tool Question
You could do what many of us do, part it off slightly longer than your target length and face it to the correct length.
olcopper
Carbide tip cut off blade, they actually work good if you sharpen and make them rite
Not my pic ,
olcopper
LOL... Good advice and I've been cutting long all along anyway. Right now I have zero confidence in my ability to part perfectly.
Not my pic ,
Hmmm... That's a clever idea. I have plenty of old saw blades stacked up that I never got around to sharpening. I like it!
Thanks
Your cutter is I bet bending downward or flexing causing the cut your getting. Make sure your tool and compound are not to far to the left of the table lock your table and tighten your Gibs then try your cut I bet it will improve greatly. Takes quite a bit of pressure to do a parting job on small lathes they just don't have the mass to absorb the bending pressure related to the cut. I use to sharpen my blades and make a small relief on top to make the chips curl easier it seemed to help a lot for me.
Another way to use the saw blade carbides is to unsolder them and resolder to a parting tool. Its easy to do
and saves the cutting and can be applied to a stiffer parting device. Its done with a brazing torch,
flux, a bit of silver solder and relatively easy to do.
[QUOTE="
flux, a bit of silver solder and relatively easy to do.[/QUOTE]
Wow, I didn't realize it was only solder holing those on. Thanks
[QUOTE="
Wow, I didn't realize it was only solder holing those on. Thanks[/QUOTE]
It's called silver solder and has a tensile strength of between 40,000 and 70,000 according to Harris Products Group.
Although called solder, it is nothing like the typical plumbing or electronic solders which are a mixture of lead and tin
traditionally. Silver solders have a melting temperature of somewhat over 800 degrees F. Silver solders are usually
an alloy of copper, tin and silver and is available in various mixtures of these metals depending on use and strength needed.
