- May 26, 2015
- 875
I had to make a mounting plate to use the OXA QCTP on the compound slide.I have a boat load of these lantern type holders most likely bigger than what you need also . Not sure of the oxa sizes .
My lantern tool post is about 2.5" or 2.75" tall. It will accept up to 3/8" tooling. The ring is cracked all the way thru where the arrow points to. The key would be 3/8" x 1-3/4" roughly.I found another rocker for a lantern post , this is a little larger than the first .
Yeah , OK . I'm sure either would fit that post .My lantern tool post is about 2.5" or 2.75" tall. It will accept up to 3/8" tooling. The ring is cracked all the way thru where the arrow points to. The key would be 3/8" x 1-3/4" roughly.
Go to any post by mmcmdi and click on his name (in blue). That opens a small window that has an optionCan't figure out how to send a private message with my address????
I did that, as you suggested, but I guess this new forum format doesn't have a Private Mail or message.Go to any post by mmcmdi and click on his name (in blue). That opens a small window that has an option
to start a conversation by clicking on the box.
Not sure I understand this. A "conversation" is a message or PM that goes to an individual.I did that, as you suggested, but I guess this new forum format doesn't have a Private Mail or message.
