Another “Yes!” for both 5C and ER40 collets. A spindle bore that’s too small for the job can add multiple times the hours to a job. I just finished machining both ends of 6 pieces 1-1/8” all thread. Both ends had to be faced and center drilled. One end needed to be cut back to 0.8735” diameter x 0.730. The other end had to be cut back for 3.14” of length and 3 different diameters. Because my spindle bore is only big enough to accept 1.00” stock the steady rest had to be used for every operation and the all thread had to be supported in a sleeve that I had to make. There was a constant battle between having the steady rest tight enough to prevent chatter and so tight that it burned the oil. I could have done it all in an hour or so per piece in a lathe with a big enough spindle bore that the workpieces could be chucked with just the end sticking out. Having to do the workarounds it took about 70 hours. It’s a volunteer job so it’s just my time; no money changes hands but I wanted to pass it along to demonstrate how the wrong lathe can be very costly.
If you intend to sell on Amazon your production has to be very efficient and keep up with demand or your reputation will go down the tubes in a heartbeat. You might want a manual lathe but it sounds like a CNC machine is better suited for your expectations. This is coming from a 100% manual machining guy.
