Ok... Who's done this before...
GREAT TASTE!
LESS FILLING!
I mean... 80s flashback.
The lathe actually came first (according to wikipedia), and the milling machine was an extension of that. Don't know if it's definitive, but if you read the Dave Gingery books, he starts with the lathe, and everything is built from there.
:whiteflag: I have done both. Usually depends on if a job is set up on one machine, and have no other choice.
Use what ya got handy:rofl:
Boy did I ever have to hunt for these photo's
When I made my first clock I did not have a mill so everything had to be done on the lathe .
But later when the lathe cooked its speed controll system, I had to turn in the mill for a while.
Error in my dowload you will have to open the first pic
Use what you have, what you dont have make.
Brian.
8-cutting 2 winding rachets.JPG P1010150.JPG P1011072.JPG P1011073.JPG P1011074.JPG
My old Taig lathe had the milling attachment - 3/16" max cutter. I've probably used the mill to help make a flycutter or something, not often.
This thread is getting dangerous. Tony's comment about faceplate turning on a horizontal mill opens up a few possibilities. I'm thinking I could easily go to 16" on faceplate or 12" with a tailstock hanging from the overarm. A V40 faceplate/chuck adapter is now on the project list.
Lathe. Most of the basic components of a lathe are round.
Tool holder, Bed, Cross slide.
However you are correct, the lathe was 1st. The "important' parts that made things round could also make the other parts that were required.
Pulleys for variable speed drive, threads for screwcutting.
Cheers Phil
