Went out and found the box of rebuilt spring packs to take a pic and found an unexpected surprise.
Here’s a couple pictures of a rebuilt one and a pic of the bunch in their nest.
Each of those probably has somewhere between 50,000 to 200,000 cycles on them and there’s no appreciable wear. The shoulder bolt wears and the 3/8-24 set screw threaded into the end of the modified stripper bolts need replaced every so often, but the bodies of these are remarkably durable.
Can you find the anomaly in this pic?
But - soft steel and tool steel deflect the same in their elastic region - the region we are typically using on a lathe. So a boring bar made of either, won't have significantly different deflection. The tool steel one with resist marring, scratching, denting, wearing, but it won't really deflect less than the one made of A36, assuming identical dimensions and use.For elastic deflection (ie, doesn't bend permanently) and a given geometry, the elastic modulus of the material controls how much it moves for a given force. Aluminum moves about three times more than steel. There's very little difference amongst the steels. Tungsten carbide moves 1/3 as much as steel. Thus, people make long boring bars out of carbide, not Aluminum! The additional stiffness relative to the bar diameter can get you quite a bit farther into a bore!
The next question is how far can you bend it before you either break it or put a permanent bend in it. Aluminum is a LOT of motion before you get a permanent bend, and carbide is a TINY motion. Of course, the forces required to -reach- that bend are radically different Soft steel and tool steel are very different here; much more force required to bend or break the hardened steel.
Sent from my SM-S911U using Tapatalk
From my seat of the pants experience I can agree with this.For elastic deflection (ie, doesn't bend permanently) and a given geometry, the elastic modulus of the material controls how much it moves for a given force. Aluminum moves about three times more than steel. There's very little difference amongst the steels. Tungsten carbide moves 1/3 as much as steel. Thus, people make long boring bars out of carbide, not Aluminum! The additional stiffness relative to the bar diameter can get you quite a bit farther into a bore!
The next question is how far can you bend it before you either break it or put a permanent bend in it. Aluminum is a LOT of motion before you get a permanent bend, and carbide is a TINY motion. Of course, the forces required to -reach- that bend are radically differentSoft steel and tool steel are very different here; much more force required to bend or break the hardened steel.
This may be true in theory (See my earlier thoughts on academic vs real life) My seat of the pants knowledge differs.
I may or may not be using the correct terminology, but in a hardened state steel is certainly more rigid or stiffer. By how much I have no practical way to measure, just my personal experience in dealing with stamping dies for a couple decades.
This is the kind of thing where I would drive the engineers crazy at work. They point to the book and say it is gospel, I simply make a part that according to the book should work in a similar fashion and eventually fail and it turns the book on its head and fails immediately.
Another thing in this vein that drives some people crazy is I usually dont use drawings for the things I make. Some long hand math and crude sketches yes, but drawing up a proper print for a one off part seems like a waste of time that could be better used to correct mistakes I made from not having a print.From my reading of history, most great achievements were done in the workshop and the lipstick of math and theory was added later. For example, jet engines and early radio.
