- Oct 31, 2016
- 2,721
I will try again with the DTI. This time I will try to use one of my tool post holders to hold the DTI. I think that it will fit in my small boring bar holder.
When I cut the taper my intuition suggests that the boring bar should be parallel to the line of travel of the compound. Or does it not matter. My plan is to cut around half of the taper and do a test fit with a collet to see how close I am to the correct taper. I will put a tight fit drill in the collet I use so that the collet doesn't flex/distort when I check the taper. Then make whatever adjustments appear to be necessary.
