- May 26, 2015
- 875
Dang it! Just can't get ahead. The motor sheave securing bolt hole stripped and and now my machine no worky! Had to order a long drill bit so that I can make a new 5/16"x18 hole for the sheave. Standard jobber bits are too short and can't get the drill gun into the tight spot. I'll drill straight thru the old hole to the other side. Hard to believe the spindle wasn't cut for a keyway. The sheave has a wobble and is why the bolt got stripped out. May have to put bushing in the sheave to make it run true. The original spindle was one of the things I had to replace for the restoration as it was all chewed up. If my mill wasn't down, at the moment, I'd cut a keyway in the spindle. For now I'll drill a deeper spindle depression for the bolt to fit into. This is going to happen again without a keyway.
