Have an el-cheapo 2" packing tape dispenser, from HF. My good one disappeared.
The cutting blade is about 23mm wide and 52mm long. It is really thin, maybe only 0.32mm thick (0.0129"), and well, it has bent along the whole cutting edge. It's some cheesy, very soft steel. It's rather magnetic. Since the blade literally folded along the whole edge, the dispenser is not terribly useful. I managed to straighten it out with the arbor press, but at 0.3mm thick it has no strength whatsoever.
So I'd like to make an inexpensive replacement blade. I was thinking of using some 0.020" thick hardened 1075 spring steel for the blade, that is if I can find some that's less than a whole new dispenser! Beats me how to cut the teeth though. How could I make the triangle teeth? Or just sharpen the blade to a knife edge? (That strikes me as an accident waiting to happen.)
I was looking around for a new dispenser, and they all look like the HF one now, (or worse, with a riveted blade). Went online to the 3m site and it seems they don't want to sell their better stuff to consumers! It says industrial use only - for a tape dispenser??? Come on. My HF dispenser is actually kind of dangerous with the non-retracting blade.
Anyways looking for suggestions to either fix / make a new blade, or get a new dispenser. Here's the silly little blade. It literally folded along the whole serrated edge about 7mm from the tooth tips. Pretty junky.
Probably any junk steel of moderate thickness would be better than this. This blade material is very easy to bend. I thought of using a box cutter knife blade, they are 2.4" wide, which I could grind off the tips, but they taper to the rear. Think there's room to put in a couple holes. Have to go find some blades though, I pulled this one out of an old cast metal box cutter handle. (The blade's dull, too!) The blade is 0.025" thick and much much stiffer! The HF blade is almost half as thick. 0.0129" vs 0.025".
Is it possible to cut teeth in the box cutter blade? With what, a diamond sharp edged wheel? Can't imagine a stone lasting more than a single tooth.
Any suggestions?
