The heavily-filtered approach is predicated on a fairly slow count rate. But due to the random nature of radioactive decay there still is a finite chance of pulse overlap. So some kind of pulse-qualification scheme is needed. My code actually uses three criteria that have to be satisfied: 1. The pulse amplitude needs to exceed a user-set trigger level. This is like the simplest kind of oscilloscope trigger scheme. 2. The pulse width has to be close to the pulse width expected for a single pulse. I think this will eliminate most kinds of pileup. And finally 3. The FastPeak function returns the RMS error between the polynomial fit and the pulse data, centered around the peak. Another user-set value (called F_level in the code) sets what differentiates a "good" pulse from a mal-formed one. This will hopefully address shorter noise pulses that might originate in the detector electronics.
Regarding being able to examine the code, I probably didn't get the permission stuff done correctly. It was supposed to work for anyone with the link. I also don't know if the link changes depending on the permission, so after changing it,
here you go.
