Yes, you probably could. The steel used to make them appears to be pretty soft. The actual bit of foil containing the Am241 is in a recess so it wouldn't be at risk.Looks like you could drive that out of the carrier with the correct shop made punch and die?
Don't know about the Theremino. How about Principal Component Analysis? There's some python libraries that would run on your Pi. Unfortunately, the principal components aren't guaranteed to line up with physical quantities, but they might. Be fun to try. Run Multiple hypotheses and pick the most probable?
This is a problem that has been solved in commercial products, so we just need to dig for some papers, or ugh, glean stuff from marketing blather.
No worries! Just throwing something up in the air. Believe me, you are faaaaaaaaaaar ahead of me. I haven't designed any circuit boards for this. Waiting for the dust to settle, as they say. Haven't bought anything, just following along for the moment. Really quietly cheering this along.
Don't let's put too much into this aspect right now. I have yet to reap all the goodies from the CERN open source software. I am trying for my circuit board right now, and getting the ADC working in a trivial way, just doing the basics.
IIRC, PCA is one of the commonly-used methods to extract elemental information from spectra that exhibit a lot of overlap. This is not a new or unexpected problem, all "proportional" x-ray detectors have some spread in the detected photon energy. It's statistics.Don't know about the Theremino. How about Principal Component Analysis? There's some python libraries that would run on your Pi. Unfortunately, the principal components aren't guaranteed to line up with physical quantities, but they might. Be fun to try. Run Multiple hypotheses and pick the most probable?
Yes, the name "focus ring" is misleading. More correct might be something like "director" ring, since it just positions the sources to obtain the highest possible fluence of the 60Kev primaries, consistent with the added requirements of shielding the detector from the same primaries and maximizing the number of XRF photons captured by the detector. It doesn't increase the apparent brightness of the primary x-rays.@homebrewed Hi Mark.
I know it looks like we have a "focal point", and indeed the original diagram where I worked out the geometry makes it look like there is one, but in this case, I don't think there really is one in the way we would like. I imagine only the extremes of possible paths and the stuff that might get hit. Those X-rays that escape the shielding shadows will generally hit material everywhere outside of the shadows, and by tilting the sources to best get gamma irradiation at places directly under the diode should increase the count.
Then, when the material does deliver X-rays, again, they will start from everywhere there was material that could get a dose of gamma. X-rays will scatter in all directions everywhere, but, if lots are directly under the diode, such that the diode size occupies lots of the available exit directions, they can't escape, and we increase the count. Wow! It would be so great if we could use some kind of "lens" to concentrate and gather this stuff, but I cant think of there being a "focus" in the sense I wish for. Still, I do know what you mean.
