- Dec 24, 2013
- 19
My own metalworking skills extend to a drill press and a belt sander. I am into electronics, however, and frequently the two disciplines merge, leaving me needful of someone to make simple mechanical parts, hopefully at a better price than an all-CNC machine shop quotes a nuisance walk-in.
Currently I need two pulleys made. One is a simple idler pulley, 3 inches in diameter and 3/4 inches thick, with a half-inch hole in the middle and a relief on each side so that a 3/4" bushing protrudes enough to miss the thrust surfaces. That's the easy one. The other pulley is 3/4 inch diameter, but with a turned-down, crowned surface to drive a flat belt. I figured that there are two ways to go about this: either a constant radius across the driving surface, or a 'segmented' drive surface with a flat middle section and tapered sections toward each end.
I've attached PDF drawings of both parts and kindly solicit your quote and comments. These will remain bare aluminum, but of course want to be precise and look nice. Many thanks for your consideration.
