- Jun 7, 2019
- 455
Can you get in the gap to measure with feeler gages? 0.001" maybe a little tricky,
0.0005 and 0.001 are available as stock.
If you can generate enough force the soft lead is an excellent choice as well, used that many times in the Navy. I have used plastigage, frankly not a fan other than maybe an error check against math errors with the micrometers.
Epoxy may work but the film will be thin (beware of shrinkage on curing) and maybe OK if you can get an outside mic over the part to measure the thickness or maybe with a DTI on the surface plate.
I'd suggest a few different methods as a cross check if the measurement is critical including an "unloaded" measurement of the separate parts on the surface plate.
66B English Thickness Gage
The Starrett Imperial Thickness Gage is used in automotive, aviation, diesel and farm equipment manufacture and service and also in jig, fixture, gage and experimental work. Especially useful in adjusting tappets, spark plugs, distributor points, checking bearing clearances and gear play...
www.starrett.com
Thickness / Feeler Gage Stock
www.starrett.com
