- Aug 29, 2019
- 1,166
Okay let me start by saying what I think the shift sequence is supposed to be on the Apron/Carriage for my 5913 lathe.
Fact #1 it has a 3 position shift lever to control Longitudinal -Neutral-Cross slide
Fact #2 it has another lever that has 2 positions and it opens and closes the half nut. Down being open and up being closed. .
Shift lever for 3 position of carriage seems to work just fine.
Shift lever that opens and closes the half nut will open in the down position and close in the up position as it is supposed to.
My Delima is that when the half nut is in the closed position the cross slide and the longitudinal can each be engaged. There is a safety latch and detent pin that is suppose to be the fail safe to keep goth cross slide and longitudinal clutches in the neutral position.
I have taken the shift mechanism apart and can see nothing wrong.
So am I worrying about something that I should not be concerned about ? Or What is out of time or adjustment?
A HUGE FYI is when I bought the lathe only half of the Half Nut was there and it had 0- ZERO threads in it and the banjo and gears that drive the quick change gear thread box were broken. I have replacement gears and replacement half nuts but don't want to repeat what the idiot I bought the machine from.
Anyone who has one of these lathes or has owned/operated one could you please point me in the right direction. I may need to contact Clausing Tech support to get further help but wanted to try the forum first. Thanks in advance.
