- Apr 29, 2019
- 2,299
Start with a full coin.
Drill a hole in the center to be able to mount it on a mandrel.
Trepan off the ring at the desired wall thickness.
Use your pipe stretcher to increase the diameter of the ring so that a full coin will fit inside it with the desired force. You may need to anneal the ring to get it to stretch and not just break, the ring will want to break due to the knurling on the outside, every single knurl is a stress riser.
Glue a full coin to a flat surface with a removable glue, machine this coin to the desired final thickness, I would guess the thinner the better, It may take a few tries to learn just how far you can go.
Solder this to the ring being careful to mot melt the thin coin parts or use to much solder where it will make a big fillet on the inside corner.
Polish off any excess solder on the outside of the joint.
For this job I do not think you want or need to use a silver brazing alloy, It heat is likely to damage the parts and this will not be a highly stressed joint. Even electrical grade solder, good old 60/40 if you can still find it, will be more than strong enough and is close enough to the color of the coin that it will be hard to spot. There are silver bearing solders that have 3 to 8% silver added that will also work well and melt at about the same temp as electrical solder, they are a bit stronger and flow really well into thin cracks.
