I have three VFD's that I got off Ebay. No problems with them. One of the manufactures mentioned that even though you do not use it very often you should turn the power to the VFD on to keep the capacitors charged up. Not sure what will happen. The other thing to remember is to let the VFD start and stop the motor. Do NOT put output power to the forward/reverse switch on the mill and use that to start stop and reverse. The VFD won't like it and it probably won't last long. Also I bought some pots and have some extra ones. I bought several because the cost and shipping were better. I can sell you just one if you want. Let me know and I will send you a picture of it so you can see if it will work for you.
warrengrant@yahoo.com Put VFD in the subject line so I won't delete it. One of the members mentioned that he used the drum switch and wired it to the VFD for forward and reverse. That's a smart way to do it. I put mine in a box and just turned the drum switch on and taped in that way so no one would move it. Haven't had a problem. I wired the VFD to two three phase outlets and unplug the mill when I want to use my surface grinder. A little of a irritation but not worth buying a second VFD.
