- Nov 24, 2014
- 3,478
I want to measure the change in gap between two planar surface resulting from a change to the force pushing the surfaces together. I need practical suggestions. No LASER scanners. Just conventional measuring tools.
These are steel surfaces with fine surface texture (probably 8 or better). The parts can not be modified for this test. The surfaces are vertical. The surfaces are circular. For each measurement, I want to measure the gaps at 3 places, equally spaced around a diameter. The magnitude of the gap is .001" to .005". I want to measure the gap to .0001" resolution.
Simple explanation: Imagine, with the surfaces separated, I stick a small bead of Silly Putty, at 3 places, equally spaced around a diameter on one surface. Then I bring the second surface to bear and apply the lesser force. The beads of Silly Putty will be compressed to the thickness of the gap.
The problem is, how do I measure the thickness of the compressed Silly Putty without altering it's thickness. I don't think Silly Putty is an appropriate material.
I thought of using 3 drops of a quick curing epoxy. Spray the steel surfaces first with a light oil to prevent the epoxy from adhering. Sounds reasonable to me. I'm thinking the flattened cured epoxy beads would be tough enough to survive their thickness being measured with a micrometer.
After measuring the gap at the lesser force, I would reset and perform the process again at the greater force.
My questions to the group are: Do you think the epoxy will be OK? What material would you recommend to replace the epoxy? Is there a much better way to measure the gaps?
Thanks for reading.
Thanks for reading.
