Latest installment. TL;DR: Lathe is fully operational.
For the curious, here’s the difference between the older solid-bearing taper attachment and the newer ball-bearing model. First, the bearings themselves fit inside the sleeve that fixes the cross slide screw to the taper bed. The solid bearings were washers placed at the ends of the sleeve, not inside it.
The bearings:
They fit in the end of the sleeve at the left. Note that the opening in the sleeve is much smaller. The old one is on the right.
Because the later sleeve contains the bearings, it is longer.
The screw is narrower where it goes through the taper attachment. The old screw is at top. But the narrow section is a close fit in the sleeve.
The sleeve going in. It fixes the screw to the binder stud using a taper pin the runs in the slot. The grooves at the ends feed oil to the ball bearings.
All together. The tie-rod clamp is parked at the tail—no need to drag it around if not using the taper attachment. Installing it in the tie rod takes ten seconds. The connecting bar is damaged and needs to be machined or straightened before it can be installed, but its only purpose is to pull the cross slide with the taper (and to keep chips out of the screw when not using the taper). That will have to wait. I ran the lathe using the half-nut power feed through the whole range of the taper attachment, and it works perfectly, but for the connecting bar.
Using a dial indicator, I measured 0.009 backlash on the cross slide in the sweet spot.
I found an expensive shoulder screw from McMaster that works perfectly for clamping the cross slide nut. I made first chips drilling a hole through it for the oil.
I tapped the hole for 1/4-20 to use the original plug screw, but drove the cheap tap too deep and broke it. I’ll probably make the screw, but for now the big Allen-wrench cavity makes a good oil cup, and the oil just drips through the channels in the tap. That bolt is $22, but cutting the head off it and milling in a screwdriver slot (plus the oil hole) would make it just like the original. It sticks up too much as it is and interferes with the compound. I was happy to see that the tailstock drilled a well-centered hole.
I also carefully leveled the lathe using my Starrett 98-12. The leveling adjusters I used made it easy to match the level of the head and tail, and to raise the tail enough to level it longitudinally. That will be good enough until I can turn a test bar.
Rick “recovered from the mishap except for the bowed connecting bar” Denney
