Easy, great finish, great durability, but sloooow. The part should be prepped using progressively finer grits but don't go finer than 300. 1. degrease part 2. cover with rustblue chemical available on internet. 3. Leave in damp environment until it gets a fine coat of rust. ( 2 to 8 hrs depending on humidity) 3. boil in distilled water for 30 minutes until it turns blue/black. 4. card with carding brush (super fine wire brush available on internet). Using FRESH distilled water every time, repeat as required (it will get progressively darker with each cycle) until it will no longer rust with the chemical. I've done 2 rifles and both times it refused to rust any further on the fourth cycle. Both rifles have been out in all day rain without a spec of rust. This system is almost foolproof and is the way custom rifles costing many thousands of dollars were finished back in the day. The only thing that will spoil the finish is oil or grease on the parts or in the water tank. I made a sheet steel tank that looks like a 3 ft piece of rain gutter. Good Luck!
