Now for something completely different...
No, not a man with three buttocks. (with respect to Monty Python)
I decided I'd try something I hadn't seen done with the top cover on the lathe. I have a tendency to put tools (chuck key, wrenches, etc) on the top of the lathe so they're right at hand. After going to the trouble to paint this thing I didn't want it to immediately get all chipped, so I started thinking about how I could keep that from happening.
Plastidip to the rescue! I'd been meaning to try this on something and it seemed to fit the bill. Nice tactile rubber surface so tools won't chip, easy to clean, and even a little sound deadening. Not sure if I had an original idea or not but this is the first time I've seen this done. Also painted the back gear and feed reverse levers and the lockup handwheel on the end of the spindle. In the top pic the end cover isn't on tight hence the gray line. I may put a little satin black on the faces so there can't be a line when it's assembled.
I've also gotten more done on the QC box. My parts (finally) got here from Logan, I stripped and started painting the QC casting, and did a first pass through cleaning the gearsets and such.
Casting after a couple coats...
parts semi-clean...
Hopefully I can get this back together before my folks show up for a visit in a couple weeks... I want them to see the before pic then the real thing the way it looks assembled. Not sure if I have enough time anic:
parts semi-clean...
