- Jul 28, 2017
- 2,606
If you mean the tool can only traverse across the work in the horizontal plane (x or y, not z), then yes that's the case. Attempting a plunge cut would produce a groove whose depth is limited to the distance the insert protrudes downward from the holder. I think things would get pretty weird before you went that deep, especially if attempting it on a small mill. The cutting load would get pretty high toward the end.I did not know this (only had two indexable milling cutters test are hss).
Can someone verify this? To me looking at the endmill I would think side cutting is all of can do as well that is the only exposed cutting edge. The bottom cutting edge is actually relieved so it is the side ward action that does the cutting (ie you cannot plunge cut like you can with a center cutting hss endmill)
Sent from my SM-S908E using Tapatalk
As @ChazzC mentioned, it would be possible to use a tool like this to cut a radius on the edge of something. But it's not absolutely necessary for that -- a standard HSS end mill can do it, along with a boring bar setup. Probably a fly cutter, too.
