I have been very busy of late attempting to downsize the house and two workshops into one small house and 1 workshop in 34'C temps.
As swmbo went out for a ladies lunch I managed to squeeze in some shed time, I thought that was fair.
Set up the vertical slide to cut the slot in the cross-head guide.
I started by using a 12mm cutter but it really didn't want to go so I drilled a 12mm hole then used an 8mm milling cutter to make the length of slot followed by 12mm then 14mm.
I thought it came out mildly ok.
Then I flipped it over to do the same thing on the other side.
All was going well untill I noticed the time so did what we all know is fatal, I started trying to hurry.
Bad move, the vibration of the cutting had (un-noticed) by me tilted the vertical slide
and made a curve in the cut as shown by the red marks.
I will attempt to remove it with a 16mm cutter and hope for the best.
I'm actually surprised that no offensive language ensued, I must be growing up.
