- Aug 17, 2018
- 22
Well I got the arbor / drawbar out, used a little piece of exhaust pipe that JUST fit over the arbor driver pins and landed on the collar, used a couple of washers and one of the arbor spacers and the arbor nut and engaged the back gear and held the pulley with my hand and cranked a half turn or so then popped the drawbar with a brass hammer and she popped right off.
I have dismantled the table and removed the knee and think I found the source of grumbliness, the helix gears which translate the handwheel to the vertical shaft, are a little rough, one has a some small steel bits ground into the teeth so I'm going to use a fine tip polishing stone on the Dremel to try to remove them. The axial gears, the shaft within a shaft are nice and clean, greased them and reassembled.
I still need to find a way to get the arbor driver off, maybe it would be best to wait until I get the spindle out??
Any ideas on best way to remove the arbor driver?
Thanks again for the help.
Cheers
Cheers
