- Nov 14, 2016
- 3,336
Maybe a bit late now, but I was given a great tip when turning cast iron. Get one of the cheap straw colored paint brushes (they are actually called chip brushes) and hold it or otherwise secure it behind the cutting tool to deflect the chips. I did this when I turned some back plates and it made a huge difference. These brushes are also handy for general machine clean up as well.
Another thing I did in my shop was to put in some screw in hooks for a heavy duty shower curtain. This also really helps to contain the chips when you have a job that is messy. I have a low ceiling so hooks in the joists works perfect and makes it easy to move it where needed in the shop.. If you are in a garage with a typical 7-8 foot ceiling you might need to get creative and add some sort of extension so the curtain hangs close to the grou d.
